ez at nova
I hate rice
- Jun 4, 2001
After I filled the tank to the brim the other day, the next morning I noticed a gas smell in the garage. There was no wetness on the floor and it didn't smell in the engine bay, but the first place I looked was undernear the tank in the back and it was all wet where the neck meets the tank. I can't see a specific hole where it is leaking so I'm thinking is is more or less seaping out around that joint. Is this a common problem with an easy fix? (The EASIEST fix would be to not fill up the tank so it's all the way full, but that's not the RIGHT way) Or, should I suck it up and look for a new tank.
On the topic of new tanks. Can anyone provide insight to these that I found?
http://www.inlinetube.com/Gas Tanks/Buick/BGM307A.htm
and
http://cgi.ebay.com/ebaymotors/ws/e...tem=7915055231&category=33556&sspagename=WDVW
One says 17 gallons and the other says 21! They both say TR specific though, which I know is important. Is there any other parts I'd need besides that tank with the neck and new seal for the sending unit? I imagine the tank swap wouldn't be that hard, right? As simple as draining it, loosening the straps, and out it comes?
On a related note, my gas guage has always been quite innacurate (when you fill it, it goes past the F so far you can't see the needle, or I've run out of gas when it say 1/4 full, etc). Would it be worth replacing the sending unit while I'm in there? I checked the plug on the back of teh dash and it looks fine.
Thanks!
Jeff
and
Thanks!
Jeff
