Garage inventory part 1
projectmoneypit
tx firefighter
I have no room to work so i spent the last 2 days going thru parts laying around the shop. This is only about half of what i have left from the parts cars. I will do another list as this one dwindles down. If you dont see it ask, even if it is some small part that you dont think i will have. Thanks
Greg 817 202 7258 I will do pp or check or m/o prices are plus shipping. Pics on request.
REGAL PARTS
PART DESCRIPTION PRICE PART LOCATION
INTERIOR
#5 HVAC VENT BOX MOUNTS TO BULKHEAD BEHIND DASH $20 O/H 2 SHOP ATTIC
#7 LEFT REAR LOWER SAIL PANEL GREY/BLACK $15 SHOP ATTIC
#8 LEFT UPPER REAR SAIL PANEL GREY/BLACK $10 SHOP ATTIC
#9 RIGHT UPPER REAR SAIL PANEL GREY/BLACK $10 SHOP ATTIC
#10 RIGHT LOWER REAR SAIL PANEL GRE/BLACK $15 SHOP ATTIC
#13 REAR METAL HEADLINER TRIM $10 O/H 2 SHOP ATTIC
#26 POWERMASTER BRAKE PEDAL ASSY $30 O/H 2 BOX 1
#29 DASH HARNESS RADIO PLUG CUT 1 SPLICE $150 BOX 1
#37 LOWER DOOR PANEL SEALS $10 PR BOX 1
#47 PASSENGER UNDER DASH COVER $10 O/H 2 BOX 1/2
#48 SEAT BELT TENSIONERS 2 PAIR O/H $10 EA BOX 2
#49 DOOR JAM VENT $10 BOX 2
#50 DRIVERS SEATBELT GUIDE GREY $10 BOX 2
#51 REAR TTOP HEADLINER TRIM GREY $30 BOX 2
#52 DRIVER TTOP A PILLAR TRIM GREY $15 BOX 2
#53 PASSENGER KICK PANEL 3 PIECES GREY $30 BOX 2
#54 DASH CLUSTER DASH PAD GREY $30 BOX 2
#56 RADIO BEZEL NICE NO BROKEN TABS $15 BOX 2
#58 PASSENGER LOWER PIVOT SIDE SEAT TRIM GREY $10 BOX 2
#59 TTYPE HORN PAD WITH HORN PLATE BURGANDY $10 BOX 2
#61 GREY STEERING COLUMN FLOOR SHIFT TILT COMP $150 SHOP ATTIC
#62 GRAND NATIONAL FLOOR MATS (4) BURGANDY $100 SHOP ATTIC
#63 REAR VIEW MIRROR $5 BOX 2
#68 BURGANDY SUN VISORS NO MIRRORS, REDONE $50 PR BOX 3
#70 GLOVE BOX INSERT $10 BOX 3
#71 HVAC CONTROL HEAD COMPLETE MANUAL $40 BOX 3
#72 HVAC CONTROL HEAD FAN SWITCH KNOB BROKEN $20 BOX 3
#74 LARGE GREY TTOP CENTER TRIM NEEDS PAINT $25 BOX 3
#75 PASSENGER B PILLAR GREY FOR TTOP $15 BOX 3
#79 FLOOR SHIFTER ASSY WITH CABLE NO HANDLE $50 BOX 4
#89 HVAC BLEND DOOR CABLE $10 BOX 2
#90 GLOVE BOX LATCH/LIGHT SWITCH $5 BOX 2
ENGINE COMPARTMENT
#1 86-87 INNERCOOLER $60 SHOP ATTIC
#2 84-87 RADIATOR CORE SUPPORT $75 SHOP ATTIC
#11 MAIN HVAC HOUSING ASSY FOR BULKHEAD $75 SHOP ATTIC
#22 PASSENGER PLASTIC INNER FENDER $50 SHOP ATTIC
#30 INNERCOOLER FAN $15 BOX 1
#31 A/C CONDENSOR $20 SHOP ATTIC
#32 HEADER PANEL TOP BRACE $15 O/H 2 BOX 1
#34 BLOWER MOTOR WHEEL $5 O/H 3 BOX 1
#35 ENGINE OIL COOLER ADAPTER AND HOSES $40 BOX 1
#36 HOOD HINGES O/H 2 PR $15 PR BOX 1
#38 84-85 HOOD TURBO HEAT SHIELD $10 O/H 2 BOX 1
#39 A/C DRYER $10 BOX 1
#45 POWERMASTER COMPLETE INOP MOTOR CLICKS $80 BOX 4
#60 THROTTLE CABLE $20 BOX 2
#64 COOLANT OVERFLOW BOTTLE WITH CAP $10 BOX 2
#65 CRUISE CONTROL CABLE $10 BOX 2
#66 CRUISE CABLE SERVO BRACKET $10 BOX 2
#67 HOOD RELEASE CABLE $10 BOX 2
#82 UPPER SPEEDO CABLE $10 BOX 2
#85 86-87 ACCELERATOR CABLE BRACKET $10 BOX 2
#86 WASHER BOTTLE WITH CAP $10 BOX 2
#88 DRIVERS INNER FENDER WELL TIRE RUB HOLE $20 SHOP ATTIC
#91 FRONT RAD SUPPORT CROSS BRACE 2PCS $10 BOX4
#41 WIPER ARM ASSY $20 BOX 4
BODY
#3/4 REAR WINDOW W/WO/DEF $40 SHOP ATTIC
#12 DRIVER DOOR WINDOW $40 SHOP ATTIC
#15 HOOD TRIM NO DINGS NEEDS PAINT $25 SHOP ATTIC
#16 RF WHEEL WELL TRIM NEEDS PAINT BLACK $40 SHOP ATTIC
#17 RR " " $40 SHOP ATTIC
#18 LF " " DENT DING PAINT $10 SHOP ATTIC
#19 LR " " $15 SHOP ATTIC
#20 LR " " $10 SHOP ATTIC
#21 RR " " $10 SHOP ATTIC
#23 84-86 GRILLE MELTED DRIVERS TOP NO BREAKS $30 SHOP ATTIC
#40 TRUNK LATCH NON ELECTRIC $7 BOX 1
#42 GAS TANK STRAPS $25 BOX 4
#43 PASSENGER QUARTER WINDOW TRIM NICE $20 BOX 1
#44 DRIVERS BLACK WIPER ARM GOOD SHAPE $10 BOX 1
#46 TAILLIGHT FILLER NO LICS PLATE LIGHT $15 BOX 1
#57 DRIVERS QUARTER EXT HOLES FOR SPOILER $15 BOX 2
#73 PAIR OF QUARTER WINDOW W/1 SEAL NO TRIM $40 BOX 3
#78 PAIR QUARTER EXT NO SPOILER HOLES $30 BOX 2
WIRING
# 76 CRUISE CONTROL HARNESS AND VAC HOSE $25 BOX 2
#77 TAILLIGHT HARNESS FROM DASH TO TRUNK $30 BOX 2
#80 TAILLIGHT FUEL PUMP HARNESS F/P WIRES CUT $30 BOX 2
#81 REAR WINDOW DEFROST WIRING HARNESS $10 BOX 2
#83 PASS DOOR WIRING HARNESS PW PL CONCERT $25 BOX 2
#84 DRIVER " " $30 BOX 2
MISC
#24 51.5 INCH 200R4 GN DRIVESHAFT $75 SHOP ATTIC
#28 USED STOCK REAR COIL SPRINGS $25 PR BOX 1
Please send me pics of the following items if you would to ecalzada1@verizon.net
REGAL PARTS
INTERIOR
ENGINE COMPARTMENT
BODY
WIRING
MISC
I will take the burgandy horn button and ring. not cracked I hope
there is no ring just a horn cap with the ttype medallion and the metal horn plate, here is a pic.
