sixtoes1313
- Oct 6, 2007
$1500 For all- Abingdon MD. 4435284474- ADAM. Please call or Txt
Quick performance 9" housing and strange 31 spline axles- comes with C&C machined seal holders to correct the axle leak problem QP refuses to address. GM metric caliper disc brake kit-. Detroit truetrac 31 spline street locker- IMO the best street unit to use. Not noisy like a normal detroit and no clutches to go bad. Less than 500 miles use. two sets of 4.11 gears. Strange iron 3rd member with larger side bearings. Comes with shims and spacers for pinion bearing assembly. Needs to be reassembled/setup with new bearings. Pictures are not current- All items have very light surface rust from several years of occasional street use.
