xtremexnyc
- May 29, 2001
Hello All,
Went to start my TR after a couple of weeks sitting. Turned the key fuel pump primed and car started for about 5 secs and then shut off. Tried to start it again and all it did was crank. Notice that when I tried to restart the car and the fuel pump did not prime. Check the hood mount fuel gauge and no fuel. Also have a fuel gauge on the rail and no fuel. Checked the 30 amp fuse to the Hotwire kit and it is good, checked the connectors to the Hotwire kit at the tank and all looked good. Go and turn the key and I hear a click which I assume it is the hot wire relay by the tank that is functioning. Any other fuses to check? I have a1/4 tank of gas so it says on the fuel gauge. But it may not be accurate. Will get a container of gas later to see if that is it. Any help and suggestions is appreciated.
Thank you
Thank you
