I have an 85 Monte with an Ls6 Vette engine and i'm running a stock GN pump. I have an adjustable fuel pressure regulator that is adjusted from 47 psi for a stock GN pump to 62psi that the ls engine needs. The pump has been in the car for about 4 years now, but i'm having some problems running lean on the top end. I believ the stock pump is running out of pressure/volume on the top end. I want to upgrade it but I don't need anything radical. I have heard of using the 89 Turbo Trans Am's fuel pump but am not sure about that. I want to keep the stock in tank pump also. Any ideas of what I can do? Thanks
Ron
Ron
