P8riot0366
- Aug 20, 2015
I just (3 months ago) installed a Walbro pump and hotwire kit, new 60# injectors, and TT chip. I also replaced the oil cooler hoses and put in a new Optima red top battery.
For some reason, the fuel pump won't run when the key is turned. When I put a power probe to it, it runs and charges the rails, but the car won't start.
The engine harness is butchered, thank to the previous owner.
I get tach activity when it cranks and it will try to start with starter fluid in the intake.
I have the service manual and traced some wires, and here is what I've discovered so far:
The oil pressure sensor is not on the car and the sending unit has been jumpered.
The pink/black wire has been cut and spliced to bypass the fuel pump relay.
The wire then goes to the brown wire of the injector harness and is spliced into a red wire that goes to the ignition slot on the fuse block.
The car ran until I installed the stuff listed above, and had a stereo installed. In fact it ran until I parked it in the driveway to look at why it was running rough. There it sits. I have been wrestling with this issue for months now.
I'm not an electrical guy, but I know how to use a multimeter and power probe, kinda-sorta read the wiring diagrams.
I had seen some drawings posted in these forums (now gone for some reason) that seemed to address the connectors and what to test for, but the weather wouldn't cooperate to let me troubleshoot until recently.
I have searched these forums to find information and have found some things that have allowed me to eliminate some causes, but I still can't find the root cause.
Any suggestions would be greatly appreciated.
