Car wont start today. Looks to be fuel related.
Fuses are good.
I have 12 volts at the fuel pump jumper on the drivers side, but when I connect the jumper together I don't hear anything from the pump. Pressing down the valve on the fuel rail results in nothing....no fuel spraying out. Not even a drop.
Is there anything else to check before dropping the tank?? Is it possible to check for 12 volts at the pump with the jumper plugged in without dropping the tank?
Fuses are good.
