What kind of pump are you using that you need to keep replacing it?
big reazon said:I see no problem with it as long as it was done properly bead rolled flanged sealed and looked proper like the access panels in the newer cars.
Right. I wasn't going to use the gas axe. A nice rolled edge with multiple bolts to hold it in (or some sort of lock down hinge or clamp) would look fine i would think. Might even be able to get a factory lid from the junkyard that would work.
Too many purist. I would do it on mine.
