fuel pressure?
84turbogn
I will get in the 12's
What do I need to have my fuel pressure at? 84 gn. someone please! what is yours set to?
Right around 42# with vacuum line off and plugged...BUT...That is generally for a slightly modded car(aftermarket perf. chip, aftermarket upgraded fuel pump and adj reg)...You aren't still running the stock fuel pump, are you???
Completely stock(stock chip, turbo, injs, fuel pump, etc), it was around 38#(vacuum line off and plugged), I believe....
I've got the 340 and hot wire kit. I set it to 42# and it seems fine. still don't have a guage to test it at WOT But i'm taking it easy. Thanks for the reply!:D
