I've been getting knock at or under 10lb boost. Put a fuel pressure gauge on and was getting only about 30psi with the stock pump /pressure regulator. I figured the pump was worn out so I replaced with a Walbro 340 (not hotwired yet) and a used adjustable fuel pressure regulator. I still seem to be getting knock at/under 10lb boost. What am I doing wrong?
I set the FPR at 42psi at idle (with the vacuum disconnected and plugged). When I hook the vacuum up, the fuel pressure at idle drops to about 32-34. It does seem to go up with some boost (to perhaps 42 or so at 10lbs boost). Should the pressure drop like this when the vacuum is hooked up? Am I still setting this thing too low? Should I bump the pressure until it is about 40ish at idle with the vacuum connected?
Car is basically STOCK.
