D DOUGGN Member Joined May 17, 2011 Aug 9, 2011 #1 My fuel injectors have 280160218 and 027 stamped on them - does anyone know what size they are from these numbers or where I can find out?
D DOUGGN Member Joined May 17, 2011 Aug 9, 2011 #2 DOUGGN said: My fuel injectors have 280160218 and 027 stamped on them - does anyone know what size they are from these numbers or where I can find out? Click to expand... Anyone have any info on this?
T T-top87GN The Buick Manual CD Guy Joined Jun 26, 2001 Aug 9, 2011 #3 Are you sure you didn't mean 280150218? Maybe? If not do you have pics?
D DOUGGN Member Joined May 17, 2011 Aug 10, 2011 #4 T-top87GN said: Are you sure you didn't mean 280150218? Maybe? If not do you have pics? Click to expand... Yes - that is possible - kinda hard to read under the hood. If it is 280150218 what size is that? I can get a picture as well if needed.
Chuck Leeper Toxic old bastard Staff member Joined May 28, 2001 Aug 10, 2011 #5 Those are stock injs...
T T-top87GN The Buick Manual CD Guy Joined Jun 26, 2001 Aug 10, 2011 #6 Yep those are stockers. Bosch Top Feed Fuel Injectors : Injector Cleaning : Fuel Injectors : Injector flow Rate : InjectorRX.com Bosch top feed fuel injectors OHM's CC/Min Lb/hr 0280 150 218 15.6 300 29
D DOUGGN Member Joined May 17, 2011 Aug 10, 2011 #7 T-top87GN said: Yep those are stockers. Bosch Top Feed Fuel Injectors : Injector Cleaning : Fuel Injectors : Injector flow Rate : InjectorRX.com Bosch top feed fuel injectors OHM's CC/Min Lb/hr 0280 150 218 15.6 300 29 Click to expand... Jeremy and Chuck - thank you - Just wanted to make sure what the were for the turbo tweak chip.
