i was wondering the same thing as i am about to go th400. i did fill out their quote sheet for a recommendation. here is what they said.
From: "John Cameron" <jfuddle@msn.com> Add to Address Book Add Mobile Alert
To:
waltersjscn@yahoo.com
Subject: RE:
Date: Fri, 03 Mar 2006 11:14:32 -0700
Jeremy,
Thank you for your interest in Fuddle Racing Torque Converters. I am
certain
we can make a converter that will not only perform well, and hondle the
power you are making, but will save you a lot of money in the process.
With your setup, going to a stall speed of about 3300 will really get
you
the launches you are looking for and on the brake, will actually stall
higher with the boost being created. The launches will be on boost at
that
point and will really hit hard. This design will also keep the turbo
spooled
after shifts and almost cheat it into extra boost. It will make amazing
power and will handle your setup well too. I really think the 3300
stall
speed is the perfect match for your setup. It will work great.
Considering the extreme amount of power you are planning on making with
this
setup, I would highly recommend going to our HP Series for this
converter.
It is a series that is designed to handle the kind of power you are
making
with no problems. We have seen them live behind single digit cars well,
so
it is a great fit for your setup.
I hope this helps and please feel free to ask any questions you may
have.
Thanks,
John Cameron
Fuddle Racing
>From: Site Visitor <waltersjscn@yahoo.com>
>To: Recommendation <jfuddle@msn.com>
>Date: Wed, 01 Mar 2006 14:48:15 GMT
>Order Date - 3/1/2006
>Order Time - 7:48:15 AM
>Make - buick
>Model - grand national
>Year - 1987
>Weight - @3400
>Engine - 231 V6 turbo
>Engine size if not stock - 234
>Injection - Fuel Injected
>Transmission - Th-400 W/ transbrake
>gears - 3.42
>tires - 28x10.5 ET DRAG
>Camshaft - 224/224@.050 .560lift int&ex
>Heads-C.R. - Alum champion GN1 9.0:1
>Intake Mods - 249cfm@.600 in
>Exhaust - 219cfm@.600ex
>Nitrous/Blower - Turbocharger
>Nitrous shot -
>boost - 25-30psi / pt-70 turbo
>Altitude - sea level
>Use - Track first, Street Second
>Future - transbrake car will make enough power to run 9.70's-9.90's.
>Customer Name - Jeremy Walters
>MailFromAddress -
>submitForm - Submit
i am still not sure about them though. i did notice that on their convertor sizing it was 245MM. i had a metric art carr(nevada) convertor that slipped really bad then was killed. i sent it to Art Carr(cpttrans) and was told the metric convertors are junk. that was straight from Art himself. so, i am still not sure about them. i know this probably doesnt help much, sorry. jeremy
