LavaSurfer
- Jan 24, 2004
1995 Impala SS. It is in very good shape for its age and only has a couple minor cosmetic issues here and there. Recently I have gone through the motor and replaced ALL the hoses, belt, battery, water pump, basically every tune up related or wear item is new or like new. I have done quite a bit of modifications to it also which includes a custom computer tune, headers (these cost me 1200+ alone), K&N intake, 1.6 roller rockers, full exhaust, along with some other small things. The motor was rated at 260hp from the factory, and I would guess its in the 290-300 range. I have also redone the interior. I replaced the gray carpet with black carpet (was about 500 alone), two toned the door panels, and I built custom fiberglass door panels for the speakers in the front door. I paid close to 900 for the CD player and speakers. I have also redone the suspension. It has Hotchkis springs (lowered it about an inch below stock), Bilstien shocks(these are the HD "stiff" shocks that are recommended for use with these springs), new sway bar bushings. The brakes have also be recently replaced (less than 5k on them) with new rotors and hi-performance carbon metallic pads on all 4 corners. There is too much to list and things I might have forgotten about that I've fixed, replaced, or improved upon with the car over the years so if you have any questions please just give me a call. Call Robbie at 615-414-1083. I can send more pictures to serious buyers.
