Well the fronts done all new bushings , tie rods , centerlink , spring and shocks . But The cross shafts that came with the PST kit are offset ( My frontend guy said this is done because over time the frame starts top pull in and what not ) However on my car that hasnt happend so now the alignment is off and the Nuts are at the end of the bolt with Max shims and the fronts are still leaning in at the bottom ( Not good ) . So either i go back to the straight shafts which were also maxed on shims and have to go through the labor and cost , or the new plan is to install longer bolt to add more shims to get it right and they cam go down as needed . Does anyone know a PN# for those 4 bolts that hold the upper A arm to the frame . I plan to get one so i can get 4 bolts to match it that will be longer , but id like the stocker as a guide . Has anyone encontered this ? Thanks
