1 ) at the base of vac lines bolted on top of the throttle body - what do i do can i use a gasket type sealer or do i need a new one ? if so what's it called ?
2 ) at the base of the egr valve - i can see bubbles , but i can't see for sure where , i'm thinking is there a gasket down there ??
3 ) adj. fuel preassure - around the the base where you adjust psi - that one ticks me off as it's new well about 5 years old with only about 50 miles on it.. maybe i can try to tighten it ???
this could be it, and i may get to realy enjoy the car for the first time in 6 years
