So the last few weeks I have noticed the AFR's creeping up. I started watching the fuel pressure and noticed it was no longer going up 1:1. I pulled the Reg apart and noticed some small cracks in the diaphragm. A quick check of Accufabs site and 30 bucks later new diaphragm is put in and I notice the fuel pressure was set way high (due to bad diaphragm) Put FP back where it's supposed to be, still not boosting 1:1.
I pull the fuel tank last night and find the two wires in the tank right before the connection to the fuel pump are melted together. The fuel line that is in between the pump and hard line is like a sponge (wrong type of line used) So I'll be calling and ordering a new set up from racetronix in a bit.
So then I go to the front of the car and notice the Alky pump is leaking. So I pull the pump and find it is engraved on the end 9/29/09, hmmm may be time for a rebuild. Needless to say I'll be calling Julio in a bit also.
Moral: Wideband's are worth their weight in gold and watch your gauges!
