TurboTA3.8
You wont keep up the pace
- May 24, 2001
89 tta 19,xxx miles on body have complete interior just not installed body is in very good shape needs new rear wing has new moser 12 bolt with a spool and 350 gears 90/10 shocks in the front 50/50 in the rear drag springs on all four corners fuel tank is sumped 2 / 8an lines -6 return line areomotive pro-series pump and filter included .also has msbc with co2 system included 10 point cage subframe conectors factory original wheels with factory metal screw in valve stems ,pa kmember setup for v6 or v8 applications front mount pte intercooler ,factory harness is still in car , underhood has fresh paint have alot of parts to go with car take all the tta stuff i just put $2000 in spohn suspension in the car panhard adjustable,adj. torquearm with xmember for powerglide,adj lower controlarms , pro drag rear swaybar and controlarm lowing brackets. comes with a 2 gta wheels with slicks on them and the 4 factory original wheels has a front mount in the car
$7200
$7200
