novaderrik
- May 12, 2004
which booster is it- the big one or the smaller one?
Why dont you stick on the right master cyl that matches those calipers...
However, my thought is that the pads are the issue. Need to get some good high performance street pads. Try some Hawk's or Performance Friction pads. RemoveBeforeFlight
Actually I am using PFC front pads. I guess it's possible that they weren't bedded in properly.
OK let's close out this post. My brakes are good again, at least as good as I would expect them to be. They haul the car down from speed with some authority now. To recap what I did and what I think made the difference:
1. Cut the front discs, lapped the pads and bedded them together = no difference.
2. Replaced the rear AL drums with new steel ones (NAPA P/N 440-1359) = no more pulsations
3. Rebuilt my AL master cylinder (24mm/36mm) with a kit I got from RockAuto (Raybestos P/N MK1486) and bled it good on the bench = looks better in the engine compartment than the rusty cast iron one. See below.
4. Bleed the brakes twice. The first time made no difference. I did them again using a different technique. I vacumn/gravity bled them this time. I put the mity vac on each bleeder (one at a time of course) and pumped it up. I then cracked the bleeder and let it flow. While it was flowing I tapped on the respective wheel cylinder or caliper. I also tapped on the proportioning valve before I started in the rear. I tapped the steel lines also. The logic here was dislodge any possible air bubbles hiding within. After this last bleed job which occurred after the MC rebuild replacement, my brakes were back to very good again.
I've been riding the GN like this since the summer when I finally finished doing all this stuff and I'm happy to say it was mission accomplished. Thanks for all the little tips that got me thinking of which ways to go. I think the biggest difference, which is probably the solution for many others who also have brake problems is a real good bleed. I haven't been to the track since so I don't know how much boost they'll hold at the line, but I can hold ~7 psi in my driveway with street tires which is pretty decent in my book.
Hey Mike, glad you got them squared away. I'm almost finished my second LS1 brake installation, now on my dark red T. I did the fronts first, of course. Less of a job than the rear, and I was going to wait to do the rear but one of my rear wheel cylinders was leaking, so rather than fix it I opted to complete the installation by changing over the rears. By the way, since I went with the high performance pads on my GN, my brakes are nothing less than awesome, but I digress. I didn't want to spend $85 just for front pads this time around. As you know, the autozone pads wouldn't stop the damn car, so I thought, just for the hell of it, I'll buy the cheapest pads ADVANCE sells ($22) and give it a whirl. Surprisingly, they're not bad at all. No fade as with the $45 Autozone pads. Spiffy, huh?
