Just tryin to get an idea on what the most common source for a pretty good leak around the front of the trans, would be ? It doesn't leak much under normal daily driving, but it was dripping after a run at the track. I've looked at it while someone else power braked it up on a jack & stands, but cant tell where it originates ? Trans is clean and the fluid is so transparent, that it's hard to see. It doesn't seem like it's wet around the pump, pump bolts or front seal. Converter seems to be dry also. I thought it was the pan gasket, so I tightened the bolts again which seemed to help until I got back to the track. The first time at the track this year on my second pass, they pulled me off the line cause it was dripping. It seems like the minute it's under a heavy load, it starts leaking. I'm going to get it leaking again by doing a burnout in front of the house and immediately jacking it up to try and figure it out. Any other comments would be helpful. Bruce ? Chris ?
Thanks again,
Thanks again,
