The other problem since the fittings may/will be an issue.. if you blow the fitting of the pressure side you will have lots of flow..but none into your engine.
All the newer kits as of late last year have pressure sensing. This pressure sensing is to be used to monitor the system. If there is an issue.. the response of the pressure sensing will show it.
Maybe another way to state it.. I have not had any pump fail that was built after Oct 2005 when the updates when into effect. Procedures have made a bullet proof pump.
If you dont have the updates.. I would suggest contact me off list
