Cal I think I see where the issue is from the help menu. The shop told me that the sensor output is going to the grey wire which is is pin B aux analog instead of pin B Aux shaft? does that sound right
2.1.19 ANALOG
This connector houses the 8 analog inputs that can be used for things such as fuel pressure sensor, oil pressure sensor, EGT probes, etc. An Analog Auxiliary input harness kit (part # 30-1402) is available from FASTä.
Pin A – AAUX1, blue/gray (C12)
Pin B – AAUX2, gray (C13)
Pin C – AAUX3, purple (C14)
Pin D – AAUX4, light green (C15)
Pin E – AAUX5, yellow/black (C16)
Pin F – AAUX6, blue (C17)
Pin G – AAUX7, brown/white (C18)
Pin H – AAUX8, white (C19)
Pin K – Analog return, black (C11)
2.1.20 AUX SHAFT
This connector is for the auxiliary shaft sensor input circuit. The FASTä VSS and auxiliary shaft harness kit (part # 30-1403)will supply you with the harness, sensor, and magnets to monitor things such as turbo speed and torque converter/clutch slippage.
Pin A – Inductive return, black (A2)
Pin B – AUX discrete, orange (A6)
Pin C – Discrete return, black/white (A13)
Pin D – Aux inductive, purple (A17)
