WVhillbilly
- Apr 22, 2012
ok i finally hooked up the sm today (thanks highboostgn) keep in mind car is bone stock as far as i know only thing done to it was adjustable wastegate.it has a driverside header crack so i know some readings wont matter much but id like to get as much input as possible thanks...Kevin
recall was 730 milivolts 4.0 retard
with both buttons pushed it read 085. 064
idling it read
AF 05
L8 41
BAT 13.6
INT 148
BL 150
CLT 200
ATS 114
TPS .48
IAC 20
NAL 34
the idle rpm is 750
idling it read
AF 05
L8 41
BAT 13.6
INT 148
BL 150
CLT 200
ATS 114
TPS .48
IAC 20
NAL 34
the idle rpm is 750
