russgoodman
- Jul 15, 2006
I posted this on the full throttle board as well but thought maybe more people would see it on here.
Both of these are from the track - 1/8 mile in OK so it was probably mid 90's out. Running Razors alky knob set to 6, sunoco 104 unleaded, boost set on about 25 per my autometer gauge, Eric's 6.0 WB tracking chip with PLX wb, and MT 28" tall slicks.
Some of my concerns: 1. looks like the correction factor on the chip is hitting 170 during the runs. Should I just adjust parameter 4 on the chip to like 168-170 area or is there something else I need to check on.
2. Boost on logger showing higher than my gauge - tapped into map wire behind glove box. Is this accurate or is my gauge correct? If Im pushing 30# boost I hope the car would run better than a 7.90.
3. MPH is off on the logger - due to the bigger tires??? is there a way to enter a conversion factor to correct this?
4. Doesn't look like Im revving very high into the rpms. Is it ok and just my tires throwing it off, or is my tranny having issues, or is it valve spring related? Springs are the stockers, got new ones ready to go on just have to get time to install them.
Thanks to all in advance for the assistance.
