The best way I have found is to make a plate that bolts where your DP does on the turbo. I took a piece of MDF and marked out the holes, then epoxied an air chuck where the wastegate hole. Take the valve covers off and loosen the rocker shafts, then let loose about 40psi of air in there. Worked for me I found a bunch of leaks, and finally decided it was time for my stock headers to get ****-canned (both flages warped, two cracks on passanger side, at least two on drivers side, and crossover fits like garbage.
Need any more details let me know.
Joe
