I'm now looking to lower that et a tad ...........using this !!!!!!!!!!!View attachment 207583
Thanks Dusty.
dang........................ you liked how mine drove I guess....
B
Thanks Dusty.
B
What blade stator? You can PM me if it's a secret lol
Its not a super duper secret ........it just a 17 blade . I liked the way clints 17. Blade acted vs the 18 blade he had before .
I just got Bob Bailey car running again and I have been driving it a bit and I like how the 17 blade is on the highway.
Again, that's just what I've noticed
I just have a question do you think it having a non lock up now over the 9/11 will I need to get a bigger trans oil cooler . the one I have a pretty good size .
Sent from my HTC6500LVW using TurboBuick Mobile mobile app
From what I've noticed, they all act the same on the highway, even the brake stall is pretty close. The biggest difference is the coupling point at a given HP level, if a 17 blade couples at 4600 on the 2-3 shift, than an 18 would be around 4800 with the same hp.
Well in clints car it seems to bottom out on the 2-3 shift at 5250-5300 per xfi.
For comparison my 138-140mph passes at 25psi the converter flashed to 5400-5450 with high viscous hyd oil. At 29-30psi it was flashing to 5550. 18 blade statorWell in clints car it seems to bottom out on the 2-3 shift at 5250-5300 per xfi.
Last frame of wot was 5800 with a 29" slick for me.The 9/11 was in the 5400/5450
As long as you have any external cooler you should be fine. Of course the bigger, the better though...you can't get a trans to cold.
Thanks dusty I should be good then it's a pretty good size unit
That's what they all SAY!!!!
