After a long hibernation period, my 85 GN with the custom intake setup is back running again...
After running it and driving it on the highway briefly, I now am starting to remember some other nagging problems that my setup has and more reasons why I was trying to convince people that it isn't worth the time and shouldn't be duplicated UNTIL I figure out all the bugs...I have an extreme amount of lag with the setup...I need to figure out what the heck is going on and I have an idea of what it might be...Although I think that if I had a F.A.S.T. system, I could tune it out with that...Not sure if I can tune it out with the stock ecm setup though...I probably need to do some more research on that one, though...I do still have some bad exhaust leaks now, but when the car was running before, I had pretty much no exh leaks but still had a lot of lag...I will finish sealing up the leaks this week and will dig into the lag problem farther, along with a possible cure(design change on my intake setup slightly) to try to fix the lag...I WILL eventually solve this problem, but for now, it is tricky to drive because it bogs so bad from a dead stop that it will stall if I don't feather the throttle...
Last year when it was running, I had it at the track and even with powerbraking off the line, I was still only able to get 2.6-2.7 60' times with no wheelspin and slow boost buildup...But once boost built up and the rpms came up, it shot right up...
Right now with the way my intake is set up, I have an extremely LARGE plenum volume, like 6' worth of 2.5" dia IC tubing and a CAS V2 FMIC along with the 87 lower intake volume...I have a feeling that I'm going to have to reduce that by a little bit(Some of you may already know what I am going to try)...I hate to do it, due to the downsides involved with it, but it may be unavoidable...
Oh well, I'll keep you all updated as I find stuff out...
