Yes,only with their 5 bar map sensor,it takese 12v in but sends out a 5 V signal,If you want more than a 3 bar just order a 3.5 bar,you will need to retune a but if you make the change.MOST buick guys dont run more than 38#s that the 3.5 bar reads
The 5 bar .ict file is incorrect. It reads pretty close in vacuum and starts to get way off as boost increases. I had to create my own file, so did Tony Gomes.
Okay, Cal would this file be included in the startup file that you did for me, I will also be running 160lb injectors instead of the 120s should I just change the injector size in the software?
Although, I'm pretty sure your programs already have the correct calibration, I will email both of you the 5bar.ict file. If you need to, you can call me for assistance in installing the file in your program.
