It would be hard to implement in the box, you would have an external box with PWM control input. You could get a PWM output from the egr table though, but I'm sure its not rated not for more than 2 amps.
Norbs,
The Aeromotive controller requires a ground signal to switch to High setting. I use Aux output 1 (Pin B1) to activate when TPS and RPM thresholds are meet.
