more voltage fun! even with a 10AWG ground wire the FAST voltage sensor drops as low as 12.3V during a 10 second dyno pull... my question is, when this happens the AFR goes WAY rich in the logs, but the dyno's horriba shows it staying flat... at the beginning of the pull, when my voltage is being logged at around 13.0V my sensor is much closer to the horriba... so, when the voltage drops does this screw with the FAST's WB02 accuracy?
i know the FAST sensor has to be off somewhat... it is reporting like 9.2:1 AFR but the car is running smooth and there is no black smoke out of the exhaust... the dyno shows 11.0:1... both sensors are installed in the header collectors (FAST on one side, dyno on the other)... any ideas?
