1000MileStylez
Black Sheep
- Mar 25, 2003
I have a caspers custom engine harness. On the harness is grounds and 12V connections that are connected and i do get power to the fuseblock on the harness. There is 3 main wires i need to make splice. A red, yellow and purple wire.
The red is connected to a junction block with direct battery current.
The yellow is connected to the fuse block and is hot in start and run
The purple is connected to the purple wire on the column and/or the solonoid wire.
I bought the rs232 cable from FAST to make my connection.
I have a pci serial card in my computer with 2 ports. "No ecu found".
I tried a usb- serial adapter. "No ecu found".
When i plug it in on the serial port on the mother board i get a "No communication" error.
I have changed com port numbers to ensure that im using the right port number in setup.
So im thinking that the other connections are good ones and that it detects that something is there but i dont think power is getting to the ecu.
I bought this unit used from Cottens. I then sent this unit out to FAST to have them upgrade firmware and check it out etc etc.
Nothing was needed, unit checked out fine. FAST sent the ecu back to me with a clear bill of health.
I get power to all the wires. What else can it be????
