FAST B2B, injectors, double pump
(6) 95 lb. injectors just taken out work good $240 shipped
In tank double pump assembly, works fine $200 shipped
Real nice steel radiator support $30 pick up only
Fast Bank to Bank with wideband O2 $540 shipped
and buick harness, works fine.
Passenger side door for limited. Has been in $75.00 pick up only
storage for 15 years, surface rust but no rust
in lower seam.
I am in northern CT.
Is the FAST set up a jumper harness or a stand alone harness? If it is a stand alone harness I will take it. Thanks
Count me in for the double pumper if it's a Red Armstrong unit. Would like to see pics before paying.
reply
The B2B uses a jumper harness to go from the OEM plugs for the ECM to the FAST and that is what is included.
Not sure who makes the double pump unit. I will put up pictures tonight.
