fast adaptor pin help
tdd
not sure if pin was originally hooked up or not but pin 8 on Gn side ,not hooked up on pink pin 5 on xfi side any help appreciated
pacecarta
LOGGED OUT
Staff member
pin A8 ecm is serial data for scanmaster . you would'nt need that with XFi,
no clue on pin 5 out you'd have to open box and follow trace on the board to see where it went but theres no reason for every pin to have a wire as the stock ecm had several unused pins
maybe John casper (gnvenom) will chime in as he built the box
