A Alek New Member Joined Jul 8, 2016 Jul 17, 2016 #1 How much will it benefit me to remove the fan clutch?
B "Black Ice" Member Joined Jan 2, 2010 Jul 17, 2016 #2 I was told it would be better to leave it on, cause it's just going along for the ride. The flex was turning at all times. I'm running a flex now, idk if I should take it off or not.
Jerryl Tall Unvaccinated Chinese Guy Joined Dec 14, 2004 Jul 18, 2016 #4 Alek said: How much will it benefit me to remove the fan clutch? Click to expand... Depends on the benefit you are trying the achieve. Typical HP benefit listed on the www at about 10 hp. AC, coolant temp and engine bay airflow/temp cooling benefit from removal is negative xx. We want air flow to keep temps in the engine compartment in check for both AC/cooling and HP (heat soak).
