Here are my numbers generated with scanmaster 2.1 At 70+/- cruising down interstate O2 mlv fluctuated between 101 millivolt and 550. Retard shows 0 degrees no matter what, backfires at boost -- can't reach WOT. AF reading 05 at idle, 32-47 on road. Bat voltage reading 12.3 to 12.9 TPS reads .40 at idle, can't read WOT. Can only sneak up on 12-13 lbs boost with TPS reading 3. Cross counts reading fluctuates between 07-240 on road. I'm concerned that O2 millivolts drop to 0 when at light throttle while still reading 5 lbs of VACUUM on the aftermarket boost gauge. You can imagine how badly it runs at 5 lbs of BOOST. If I coast at 65-70 fluctuating O2 numbers which may be at 07, etc. at light throttle will jump to 650- 750 momentarily. I really need guidance with this. Cruise O2 numbers get worse and then car stalls.
We drove 40 miles to get a 120 amp alt from NAPA. On the off ramp it quit and would not start. After a few minutes, I took off the gas cap which sucked air. Car started. After getting back with an alt and O2 sensor, it was cutting out, took off gas cap, tank was pressurized, ran better home, home, O2 numbers back up from 00, say 400ish, but a pig at boost. Bought a vented cap. Am headed out to install alt and O2 sensor. Anyone know of a Buick turbo master in vicinity of Carbondale/Marion, Illinois where I can drop it off? Sorry for the long post but I hope the info will help.
