F/S -- Balancer, Main Accessory bracket, up pipe, J bracket
UPDATED 6-4-2016
1- AC delete bracket with pulley---- $25.00
2- Caspers Fuel tap T-- $8.50
3- Balancer -- $50.00
4- Stock turbo elbow ---- $50.00 OBO
5- Main accessory bracket ---- $75.00 OBO
6- 4 Timing covers----??????
7- 3" inlet pipe- intercooler to throttle body ?????
8- Stock Engine cooling fan -------- $50.00
9 - Stock Intercooler in good shape pictures coming soon -- $65.00
10- Adjustable actuator -- $45.00
11- Walbro SS340 fuel pump with hanger -- $85.00
12- OE Metal vacuum lines --- $45.00
13- Stock Intercooler brackets --- $30.00
14- Main pulley -- $40.00
15- Water pump pulley $20.00
17- Monte Carlo Shifter #1 --- $80.00
18- Monte Carlo Shifter #2 --- $100.00
19- Used coil and module #1---$125.00
20- Used coil and module #2---$125.00
Located in L.I, NY
I would consider trades for the following stuff
1- 4L80E with converter
2- Rear Bilstein shocks - For GN
View attachment 261432 View attachment 261828 View attachment 263558 View attachment 263559 View attachment 263560 View attachment 263561 View attachment 263562
Timing covers.
more timing cover pictures
What has changed with this turbo in the last year. Been on the shelf,been using it .still no smoke, rubs,leaks.
The car has been sitting but i did make it a habit of turning the car on once a month and letting it heat cycle a few times before turning it off.
The car was turned on last week to show a working motor (turbo was on the car) to a buyer and it didn't smoke make any noises, took the turbo off and it looks good.
