Matt Sando
- Jan 13, 2005
Having a hard time install my fbody sway bar it seems that the end link bolts aren't long enough to get the nut on. I am using end links for the GN. anyon have any ideas or tricks to get the nuts on???
Ha ha. I may have to subscribe to this one. This would only work if they were big boned. :biggrin:Brer Rabbit said:Have the girlfriend or wife--or both if they get along stand on the engine crossmember, then jack it up.
bison said:Ha ha. I may have to subscribe to this one. This would only work if they were big boned. :biggrin:
turbofish38 said:Maybe try loosening up the 4 10mm headed strap bolts. Just enough to let the bar swing in the mounts. Be carefull not to strip the threads on the frame. Tighten them up before you torque down the end links.
