Extreme g Chip Rev limit
If it has the rev limiter enabled, it would be a fuel cut limiter. You'll need to ask whoever made it for you whether the limiter is enabled.
The chip came from Fullthrottle several years ago. according to the part # it's rev limited at 6000. I've upgraded the cam to Rev xr2 210\215 cam and I'm not sure it will see 6000rpm but it make me nervous that the chip can cut off the fuel at wot with alky pouring in.
Better get the chip changed as soon as possible. The last thing you want is a fuel cut when running alky.
