counterman
- Dec 28, 2006
Guys, I pulled the pan on my trans today searching for a thrown governor spring. I found a spring in the pan, but the governor spring is still in place. It is a light spring about 2 inches long that compresses down to about 1/2 half inch. It is maybe 1/4 inch in diameter. I have found no other items in the pan. This is a recent rebuild from my local "guru" that has had trouble since I got it back. It shifts only at very high rpm, and I have to lift to get that to happen. Once it is up in the gears, it downshifts without provocation. When coming to a stop, it will hold 2nd gear unless I pull it into 1st manually. I over revved the motor once already and popped a head gasket because of this foolishness. It downshifted at wot and sent the motor to the fuel cut off. It backfired when it relit, popping the gasket. The pan was otherwise clean of debris and extra parts except for some minor fiber and clutch material. I am figuring that the spring is from the valve body. Most likely the tv limit spring or the 3-2 control spring? Maybe a pin backed out some and let the spring loose. I haven't pulled the valve body yet. Thoughts please. Thanks, Counterman.
