if going tuner style(single hose from compressor to gate) , bottom of gate , on his the gate is sometimes upside down so keep that in mind bottom is closest to the valve side
this will yeald boost equal (or close) to the spring installed
if you blow into the top you will have boost pressure plus spring pressure and net very high boost unless you use an adjustable controller like the turbonetics adjusta boost or an electronic dual port controller
