This is a external pump with adjustable pressure regulator . It is similar to the dutt pump . It will improve your oil flow and pressure . Hardwear is included $200 shipped
At what point should someone be using this setup? Power/ET wise, Is it more efficient than just the stock oil pump configuration? Sorry for dumb question!
The pump could be used at any power level .it will give you better oil pressure And the ability to control it . It does this by eliminating abunch of sharp 90* turns . You would need to drill the oil pan for a pick up . And get a external oil filter . I like this setup becuse you feed your turbo right off the filter so it’s basiclly a turbo saver .
