Wow I didnt even know I was in an "argument".
Before anyone respond, I suggest anyone who wants to respond, go try it. Plug in the stock MAF, pull the orange power wire, plug it back in, re-program to your happy settings and see what happens. You may need a little tweaking, but it does work. I tried it 3 years back and it worked, much to my surprise. Several months back, I sold my translator and stuck the stock MAF back on. It ran ok, until the MAF burned out. I bought a new one, and its been fine since. Every reading on the scanmaster is beautiful. No problems. It actually runs much better than the LS1 MAF and translator ever worked.
When you figure that the translator only converts the LS1 signal to something our computer understands, and the extender cuts the MAF signal in half (it cuts resolution in half in order to double the range, yet re-interprets the data to resemble a standard MAF curve)...you realize the 2 arent intertwined. You can run 1 system without the other. You can run the translator and Ls1 MAF, with the stock chip...right?
The translator doesnt cut the signal in half. The extender does. The translator only converts the new style electronic signal into the old style signal. The extender does something completely different.
The LS1 MAF does flow more air, and the extender takes advantage of that. BUT, its not a requirement to run one with the other.
Or my car is just a freak from the twilight zone.
