I am having issues with this car and hopefully someone can enlighten me. I just got back from south west asia and went to crank up the car for the first time. Well, my car was smoking from the breathers on the valve covers. Before I left I was having a problem with oil saturating the breathers. I pulled off the valve cover and cranked it up again to see if one of the valves were stuck or one of the valve seals went out. They were all fine. The smoke was coming out of the holes were the push rods go thru the head. Before I left, I thought the oil problem might of been a head gasket. I had a compression test done and was fine. You can tell its exhaust from the smell. It smells like fuel. The motor is new ( new to me) everything was fresh and it has maybe 3k miles on it. Another question. Is there a chance that an adjustable pushrod loosen itself? Meaning where you adjust the backlash on them can they come loose? Can anyone lead me in the right direction here? Thanks for any info on this
