I'm now getting an error code 31 which is boost solenoid didnt respond error. I'm assuming that solenoid is the small part that was on the passenger valve cover near the turbo. It was never connected in the past, part was there with no electrical or vacuum hose connections, so I removed it to clean up the look and cut off some old connectors that were just hanging around loose, one was probably for that and another was the old oil pressure sensor (new guage now )
. Never had any errors with car before but now I'm getting it after its all back together. Is that part what I'm assuming it was and if so, why the sudden change since it never had a connection to the vacuum lines before?
