Walt Skarb
- Feb 26, 2008
I have a ticking noise coming from around #1 cylinder. I have a flat tappet Comp cam with comp lifters. Engine has about 3000 miles since rebuild and runs fine. clicking noise disappears when injector for #1 cylinder is disconnected and also when #1 plug wire is pulled. Pushrods, rocker arm assy look ok. Would the noise disappear if it was an exhaust leak? I am trying to save some work but I suspect bad lifter.
