Would i tbe possible to pull the NA 3.8 out of an 1988 LesabreT-type and replace it with a SC 3.8 out of a Buick GS? What would be some problems I may face if it can work? Thanks.
You would have to swap the engine, along with the trans, as well as the PCM and all wiring. You would also have to run the wires to the dash to control any gauges. Check out www.L67swap.com
