Interesting feedback from you all. Thanks to all for responding.
A couple of points:
Yes, synthetic oil, by its nature, will run cooler. Conventional grade oil has a tendency to "cook" in extreme conditions, as well as not providing as good of a lubrication factor as synthetics. Therefore, by default, more friction = higher temps.
My original thread was merely to get input from any of you who may have successfully eliminated the cooler completely, with no side effects. (I'm still looking for that input)
I'm not looking to replace it with a better one. I've already got an upgraded big-tube 3 core radiator (with stock side tanks), and have no need to spend $600 on another one. I've got a good external tranny cooler as well. I'm fully aware of "bearing failure", as that's the reason I just rebuilt my motor. I've got a high-vol, high-pressure pump now, which I will probably downgrade one spring-level, to hopefully not place as much pressure on the cooler line end fittings, which is what stemmed this whole discussion per a small leak.
__________________________________
For those of you who want to read further about synthetic oils, here's some general info:
Motor oil serves many purposes. Its primary function is to lubricate and protect, but it also is designed to keep your engine cool and running clean.
Under ideal driving conditions (consistent speed highway driving), conventional motor oils recommended by the vehicle manufacturer work just fine. But for many people, ideal driving conditions are few and far between. In cases of stop and go traffic, short trips, very cold temperatures, very hot temperatures (caused by weather, traffic jams or turbo engines) or towing and hauling, drivers can benefit from the extra protection of synthetics.
Conventional motor oils are made from crude oil that is drilled from the ground and processed in a refinery. Synthetic motor oils are created from special "synthesized" materials and deliver more performance benefits, such as:
Superior protection from engine wear Lower volatility for decreased oil consumption ("volatility" is the tendency of an oil to break down at extreme temperatures) Better gas mileage Easier start-ups at very cold temperatures (because they flow easier) Greater viscosity (the "thickness" of an oil) at very high temperatures Reduced engine deposits, which are the "by-products" of combustion in the engine
Also, you might check this out...
http://www.mobil1.com/index.jsp
