krisking94
- Oct 6, 2014
So I got a 86 the type a week ago. Was running fine for the most part. It would die if I got into the boost at lower speeds. Say sound 25-35. But higher pulls it wouldn't die. Then a couple days ago. Driving home from work. Got into the boost a bit around the 25-35 area. Car died. No problem started right back up. Drove a quarter mile down the road. Shut the car off went inside auto zone to check out what they had. Started car back up. Was running rough. Throttle response was getting bad. Car started chuggin. Basically limped it home. Parked it for a couple hours. Then tried starting it again. It started. But it was idling rough then the car died. And now won't start again. Replaced the MAF and replaced the crank sensor. Still not starting. Car has 3 inch single shot exhaust. Terry Houston down pipe. I believe 42.5 injectors (green band) and a aftermarket fuel pump of some sort. Has a hot wire kit for the pump. And a unknown chip. If anyone can please give me some ideas to get it going I'd appreciate it. Just got the car and it sucks it's already not running. Btw the car is getting spark
