Rigo's 87 GN
- Mar 16, 2009
im having some wiring problems with the fuel pump, i believe is the ecm but im not positive. theres no power getting to the fuel pump. i can unplug the pump and power it and the pump works so is not the pump. i can power the pump by the tan wire after the relay! im not getting the 2 second signal of the green wire coming fron the ecm! but i belived ones the engine is being crank the relay should change to constent power supply to the pump. it sounds like a relay but this system is suppose to work in conjuncton to the oil switch so if the relay is bad car should remain on by the switch!!!
i hope someone has more experience than me with this cars is a new world for me right now! Thanks!
also i would like to know how i can adjust an adjustable wastegate solenoid i just upgrade the turbo and i was looking to push a few more pounds! thanks!
