Hi guys,
I have an intermmitant electrical fault with my alkycontrol kit which could lead me to blowing a gasket so advice appreciated.
Sometimes, when I turn on the alky kit the 'alky spraying' neon is already glowing a faint red. It should be off until the alky start spraying.
I think I've traced the fault to an electrical connector which comes off the main control unit which I have behind the glovebox
. I've enclosed a pic as i'm not sure what this connector does/is called. If I unplug it and then replug it making sure its firmly connected the alky system sprays correctly. The only problem is; the system can work perfectly and then go on the blink and leave me without alky. What's the likely cause?
