I have the Caspers elect fan kit with the Valeo dual fans on my car.
Two days ago the fans just stopped working (while out driving in 100 deg heat no less). I checked the relay that comes with the kit and replaced it - unnecessarily I think.
I followed the guide on Vortex Buicks and have done a search here for help but it seems the Vortex guide is more for 86/87 cars as the wiring colours are different in the how-to-fix instructions.
I tried direct 12v power to the fans and they work.
I have 4 wires in the relay connector. One black (which I assume is ground) that goes to the 87 ECM I have and also to the fans ground connection, one is red - 12v batt power, one is pink/black which goes to another relay on the pass fender and one is solid pink that leads directly to the fans 12v power connection.
I have 12v at the relay on the red wire and ground on the black. Dont know why things arent working from there. I have no other signal when I sould because the car is over 160 deg which should be telling the ECM to turn the fan on.
Could it be my coolant temp sensor? I measured that connector with a voltmeter (yellow wire + blk wire) and the voltage was low but decreased as the car heated up. I recall it was at 3.xx volts and decreased ever so slightly from there but never went to zero.
My Autometer guage is connected to the other temp sensor at the front of the intake (one wire idiot light sensor I believe) and seems to work fine. The temp goes up and down on the guage as it should.
Anyone have any ideas?????
